08-23-2012 04:35 PM
I don't think you should be calling the initiate function which tells the scope to acquire when the default setting happens. And the default setting for an acquisition is probably a trigger. Try to manually acquire a waveform and then just run the fetch.
08-23-2012 07:56 PM
thanks.
ok, i'll try running the initialize function and then the fetch without using calling the initiate function, i think i tried this, but i'm not sure.
08-24-2012 11:36 AM
NO, NO, NO. Why do you want to run the initialize function? That will reset the scope unless you disable that. The initialize function does not need to be called!
08-26-2012 03:52 PM
hey dennis,
I did as you instructed, that is remove the initiate function, but alas, the scope still waits for a trigger,
as you suggested, this may be a scope preference, but how can i change it?
08-28-2012 11:14 AM
This is a little late to be mentioning this, but this topic would be best suited for the Instrument Control (GPIB, Serial, VISA, IVI) board, as the Agilent oscilloscope is not an NI HIgh-Speed Digitizer. You may want to post there and link to this thread to get some additional help.
-Andrew
08-28-2012 12:57 PM
ok, thanks is there anyway to change the post's category now?
additionally, I am still stuck with the original problem.
08-29-2012 04:03 PM - edited 08-29-2012 04:03 PM
I don't believe there's a way to change topics after the post began. You can always create a new post and put in a link back to this one, explaining that you're looking for help that pertains to instrument control/communication.
Unfortunately, I'm not as familiar with that Agilent scope, so I cannot advise so well on your questions.
-Andrew
08-29-2012
10:49 PM
- last edited on
08-12-2024
02:36 PM
by
Content Cleaner
Hey Ziv,
I tried searching for your new post in the Instrument Control forum (https://forums.ni.com/t5/Instrument-Control-GPIB-Serial/bd-p/140) but it doesn't look like you've asked the question there. I'll be glad to help out but I'd prefer if we kept the thread going on our Instr Control forum for future customers who might have similar questions. Could you post a link on this forum to your new thread and the referse so people can get the background on the issue?
Be sure to post what specific model of the 5000 series you are using and a quick summary of what you've already tried. In the meantime, however, have you tried running the triggering example that ships with the driver called Agilent 6000 Series Edge Triggered Acquisition.vi? If you run this VI do you still have to trigger twice? Also are you still getting old data with this shipping example?
Lars
NI R&D
