High-Speed Digitizers
Clock Sample & Triggering on a NI-5122
Hi all,
I am currently assembling a manipulation to acquire an array of photodiode (about 300 columns by 1000 rows  CMOS APS Pixels) according to “exotic” chronograms : time of latency between obturation/integration and reading of the image about 500ms to 2s, frequency of reading pixel = 30MHz.
My starting configuration is :
  •  no delay between integration and readout
  •  30 MHz clock sample into CLK IN connector,
  •  Start Acquisition trigger into TRIG connector
In this configuration i basically acquire in one sequence from the first top-row pixel to the last bottom one : about 300 kSample which i reorder in a 2D array.
 My problem is then the following: to insert delay between integration and readout, i use a pulse generator to start and stop my clock generator. By the way, when i pause the clock generator (not enough in-depth memory to generate the delay i need) , the clock sample is also paused and so the acquisition of the NI-5122 crash (Error: No clock sample). So, is there a mean to configure the NI-5122 with a non-permanent clock sample ?
Personally i've tried with an external 30 MHz clock generator but i can't synchronize it simultaneously with both my main clock generator and the NI-5122. I've also tried with a digital trigger on the PFI_0 as a Start trigger source but if the acquisition is well done, the start of it is unpredictable.
In the same idea, is it possible to start/stop  the acquisition on a multiple trigger condition on a NI-5122? For example analog edge trigging on EXT TRIG AND digital gate trigging on CH1 or PFI_0 .
Any suggestion is welcome 🙂
Alex.
(6,338 Views)
I think I don't get you right.
Why don't you start an acquisition of your 300k samples, then stop the task and, when done fetching, restart it again? As far as I'm concerned you can tell the card to fetch 300k samples and then stop.
Or is there some sort of exactely needed timing between acquisition and readout?
(6,331 Views)
