High-Speed Digitizers
Coerced sampling rate using PXI-5142 in OSP mode
When using the PXI-5142 (as a part of the PXI-5661 vector signal analyser) in OSP mode I am unable to get a sampling rate of 20MS/s.
As I understand it, in OSP mode, the IF signal is downconverted to baseband at the full sampling rate of the digitiser (100MS/s), and then low-pass filtered and decimated.  When I request a sampling rate of 20MS/s (divide by 5) it is coerced to 25MS/s (divide by 4). The next closest sampling rate is 16.667MS/s (divide by 6).
Is it possible to get a sampling rate of 20MS/s?
David
Using Labview 8.0 / NI-RFSA driver / Windows XP
(6,753 Views)
Hi David,
The restriction on decimation is divide by 2n, not divide by n. The reason for this is the digitizer is sampling a single input waveform and extracting an I waveform and a Q waveform, effectively halving the sampling rate.
In other words, an input waveform sampled at 10 MHz will yield an I waveform sampled at 5 MHz and a Q waveform sampled at 5 MHz. When you specify the I/Q rate, you're giving the final sample rate of just the I and Q waveforms (5 MHz), so the driver then tells the hardware to sample at twice that to give you the rate you want.
Asking for a 20 MHz I/Q rate asks the driver to sample at 40 MHz, which isn't an integer divisor of 100 MHz, so the rate will be coerced up to 50 MHz, giving you a 25 MHz I/Q rate.
Joe Friedchicken
NI Configuration Based Software
Get with your fellow OS users
[ Linux ] [ macOS ]
Principal Software Engineer :: Configuration Based Software
Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018)
Software Engineer :: Measurements RLP Group (until Mar 2014)
Applications Engineer :: High Speed Product Group (until Sep 2008)
(6,743 Views)
Cheers, thanks for that explanation
David
(6,739 Views)
