High-Speed Digitizers
Communicating with a LeCroy scope using TCP/IP
I am trying to communicate with a LeCroy scope (wavemaster8500) over TCP/IP. When using LeCroy pre-prepared drivers it works fine, but when using the basic visa vi, the scope does not respond to the commands
(6,462 Views)
How are you opening a session to the instrument? I have limited experience with using VISA to talk to an instrument over TCP/IP but I believe you would use a resource string like TCPIP::IP::INSTR.
Best Regards,
Aaron K.
Application Engineer
(6,462 Views)
