High-Speed Digitizers
DVD video-YUV output test using NI 5112
As we all know, One of DVD video-output type is called YUV. I want to analyze the YUV output.But i have no experience on it. I just know that YUV is composed of RGB at a scale.Have anybody got some datasheet about the scope shape of the YUV output? And how to analyze it with NI5112? Thanks
(6,241 Views)
There is an Alliance member called microLEX Systems A/S in Denmark that has a solution for component video analysis called VideoMASTER. It uses a PXI-5122 (14-bit) digitiser, some LabVIEW software, and an external interface box. The external interface is required for multiplexing the 3 component channels onto the 2 digitiser inputs, and for component video triggering, which can't be done directly with the 5112 or the 5122. The 5112 could still be used for amplitude measurement but will give much less accurate results because it is only 8 bits. Check out VideoMASTER at www.microlexsys.com.
(6,241 Views)
