High-Speed Digitizers
Error 0x80041200
Hello
I install 5102
I have Error at IVI 0x80041200 see "error_3.jpg"
Max_report.xls include Max Version
thanks
Eran
(6,647 Views)
Hi Eran!
The error you receive when accessing the IVI folder from MAX is because your current configuration location is empty.
To fix this problem, select "Open IVI Configuration" and browse to the specified Master IVI configuration location C:\Program Files\IVI\Data\IviConfigurationStore.xml. You also need to make sure that the Data folder has a file called IviConfigurationStore.xsd. If you don't have either of those files in the Data folder then you will have to reinstall the IVI drivers from NI-Drivers and Updates.
Please let me know if you can't get it to work.
Good luck,
Tica T
(6,622 Views)
