High-Speed Digitizers
Error 10403 in Virtual channel Test Panel, but test pannel for device works fine
I am using a simple 10x probe attatched to the NI5112 PCI card. When the device is tested under the devices and interfaces part of MAX, I get the scope input, when I test the virtual channel for the scope, i get error 10403. How can i resolve this?
(5,781 Views)
The reason you get that error is that virtual channels are not supported with our high-speed digitizers. Only devices that can be programmed directly with NI-DAQ support virual channels. The legal way to address a high-speed digitizer is by using DAQ::N, where N is the device number in MAX.
(5,781 Views)
