High-Speed Digitizers
Error-1074126845 occured at niScope Multi Fetch WTD
Dear all Friends,
I am using the NI PXI-8108 controller, LabVIWE 2010 and digitizer NI-PXI 5124. i am facing one problem . When i am running the code the following error is comming (Error-1074126845 occured at niScope Multi Fetch WTD) the description of error is maximum time exceeded before the operation completed. Status Code :-200284.i am attacing the code and the error. I tried with the example code. With the example code also i am facing the same problem. In the Measurement and explorer  i am not facing any problem and i get the expected  measured values.
Kindly give me the reply as early as possible.
With regards,
Niranjan.Ch
(6,917 Views)
Dear all Friends,
With regards,
Niranjan.Ch
(6,915 Views)
Dear all Friends,
  i for got to attach the code
With regards,
Niranjan.Ch
(6,914 Views)
I belive it has to do with acquisition not starting withtin the specifed time. If you look at the block diagram there should be a timeout property in Ni-Scope Fetch VI. Just set that to -1 and that would set it so the application is running till it receives a trigger.
Alok
(6,613 Views)
