High-Speed Digitizers
Error-239022 ocurred at self test. Internal HW error ocurred in MIG HW
I have 5 PCI-5122 NI cards with same error message, I replace them by a new one and not problem. Could you help me to find out a solution to these error?
(6,582 Views)
Hello Hector,
If you have tried your PCI-5122 boards in another PC but still see this error and the other board you have works in those same slots, this probably indicates you have a problem with your hardware.  Please be sure you are working with the latest NI-Scope.  To initiate the process for repair, please contact National Instruments.  You will want to have the serial numbers of your boards available.  They may suggest further trouble-shooting steps before having you return the boards.
- Jennifer O.
(6,574 Views)
