High-Speed Digitizers
Error message regarding initialization of nidaq32.dll and niscope_32.dll
I have just bought an NI PCI 5102 High Speed Digitizer Card and have tested it in NI SCOPE Soft Front Panel. However when using the NI SCOPE vi's in Labview 7.0 to perform a simple initialisation and aquisition program the program gives the following 2 errors.
"Initialization of the dynamic link library C:\winnt\system32\nidaq32.dll failed. The process is terminating abnormally."
"Error loading "niscope32.dll"
A dynamic link library (DLL) initialization routine failed."
I have tried uninstalling and reinstalling the files using the software provided with my digitizer card with no success in removing these errors.
What would be my best course of action if reinstalling the software hasn'
t worked?
(6,522 Views)
In order to troubleshoot your problem further, I need some additional information. What version of the NI Scope and NI DAQ driver are you using? If you try a LV shipping example do you get the same error? I would suggest trying the example "niScope EX Getting Started" VI.
Regards
Russell Blake
Applications Engineering
Director of Engineering
G Systems, www.gsystems.com
Certified LabVIEW Architect
Certified LabVIEW Embedded Systems Developer
GCentral
(6,522 Views)
