High-Speed Digitizers
Error while executing the example for the Tektronix RDS 1001B
I encountered an error where it reads: Error 1 occurred at Scan From String (arg 1) in Tektronix TDS 200 1000 2000 Series.lvlib:Read Measurement.vi
Possible reasons: LabVIEW:  An input parameter is invalid. For example if the input is a path, the path might contain a character not allowed by the OS such as ? or @. ========================= NI-488: Command requires GPIB Controller to be Controller-In-Charge.
The program is an example obtained from the NI website (Tektronix TDS 200 1000 2000 Series). Im trying to communicate with Tektronix TDS 1001B Oscilloscope to obtain the measurements, selecting channels, viewing waves and et cetera.
The example is to read measurement block diagram. While executing, the error is identified while reading the VISA of the measurement.
Here I enclose the following file for the example.
Please advise.
(5,712 Views)
And what is the exact string that is being returned by the VISA Read? What functions are you running before this one?
edit - You also posted to the wrong board. This is for NI's digitizers. The proper board for new questions regarding this would be the Instrument Control board.
(5,707 Views)
