High-Speed Digitizers
Hardware help
I am checking the resistance of a post.  My parameters are 147k to 153k Ohms.  Is there anything that comes to mind to use for this situation with at least 16 bit resolution?
The device that I need has to have adjustable settings for discrete I/O to go to a device like a PLC.
I've attached a jpg of a cad drawing to make my question a little clearer.
Thank you in advance.
Ron Deavers, CLD
(6,124 Views)
Hello!
In order to measure resistance I recommend using one of our DMMs. The resolution varies depending on the product and they go from 5½ to 7½ digits. These digits refer to the number of digits displayed on the readout of the DMM and you can learn more about them from our DMM Products Page.
Let me know if you have further questions about it.
Good luck,
Tica
(6,105 Views)
