High-Speed Digitizers
How can I program NI USB-5132 in VISA RAW?
The company have purchased a NI USB-5132 oscilloscope.  I was hoping it was going to be UTMC compatible as I have previously programed a Tektronix oscilloscope using VISA with the INSTR interface.
However the NI USB-5132 does not get recognised as a VISA Instr device.
I built a Visa .inf file for it and it does now get recognised as a VISA RAW device.
However now I need to program it as a RAW device for setup and measurement.
My questions are two fold.  Where is the command set for a NI USB-5132 device suitable for programming
it as a VISA raw device ( document / pdf file ).  Note I can get a UsbRaw session for the device but I am interested particularly in the equivalent of VISA Write and Read in Raw mode for this device. Looking at explanations of RAW it seems that I need to know also the protocol for the device. In preference I would like to use the simplest protocol such as a Simple Read and Write as for VISA Instr.
Secondly are there any examples of programming the device in VISA RAW ?
Thanks for any assistance.
(6,732 Views)
The NI USB-5132/5133 devices do not support the interfaces that you mention.  National Instruments does not publish the command set/protocols necessary to configure the device using VISA.
The device is configurable using the NI-SCOPE driver provided with your hardware.  You can also download the most recent version here:
NI-SCOPE 3.5.1
The driver comes with dozens of examples using the NI-SCOPE API in LabVIEW and C.
(6,728 Views)
Or you could use the IVI Scope class driver. If you had used that for the tek scope as well, you wouldn't have to rewrite any code.
(6,716 Views)
