High-Speed Digitizers
How can I recover a scope acquisition in a spreadsheet ?
Purchasing the toolkit may be the best option. I have just looked at it and it has a couple of examples which show exactly what you want.
Alternatively, have a look at the example code (LV 7.1 format)attached which uses ActiveX and doesn't rely on the toolkit.
Message 11 of 19
(4,789 Views)
Dear Stuart,
That you sent to me contains exactly the sub-vis missing !!
I hope I can use them now...
Message 12 of 19
(4,783 Views)
Excellent news! I'll leave you to explore it further.
Stuart
P.S. Feel free to rate the answers that have been given 😉
Message 13 of 19
(4,781 Views)
Dear Stuart,
Just a last question: When have I to save this to make it appear in my function palette ?
Thanks for all
Message 14 of 19
(4,771 Views)
Hiya,
Try this:
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/2d38006f8672194e86256b5200545d1c?OpenDocument
Stuart
Message 15 of 19
(4,771 Views)
Ah Stuart help,
Sorry for the short rest. I managed to put the llb in my function palette and to open the gethardcopy.vi but I can't get it work !
It seems very strange, I don't know what to do and how it works, and the VI is broken and when I try what they say in the error list nothing happens.
Can you look at that and tell me ?
Message 16 of 19
(4,763 Views)
I'm confused now as I can't find any Vi named gethardcopy.vi in the LLB that I sent you?? Why can't you just make use of the Write table and chart to xl.vi?
Also, I don't understand what the error is. Does it tell you? Is there a problem with a subVI or something??
Message 17 of 19
(4,761 Views)
Hi Stuart,
The gethardcopy.vi provided by boones is in the forum link I gave you above in this discussion.
I've tried to just use the "Write Table and Chart to XL" block but it seems desactived and links to wire don't appear...
Message 18 of 19
(4,757 Views)
Carolyne,
If you are trying to use this as a SubVI I imagine that you are having problems because none of the terminals are linked to inputs/outputs. You could either resolve this or just cut and paste the block diagram code into the VI that you are developing as this may be the easier option for you if you don't know LabVIEW basics. Incidentally, have you thought about going on a LabVIEW course or buying a book, this may help you develop your code quicker 😉
Cheers
Stuart
P.s. I would make the subVI connector pane changes but I'm currently in the process of formatting my hardrive and LV is out of action for a wee while.
Message 19 of 19
(4,728 Views)
