High-Speed Digitizers
How can we control the gain factor of the PXI-5102 Digitizer?
Dear sir, I have got one question about the gain parameters in the returned wfmInfo structure when you use fetch or read functions. Dose it be determined by the Digitizer automatically(internal) when you set the vertical range and probe attenuation? How does it be determined? Thank you very much for your help.
(6,174 Views)
Accepted by topic author sxs707
Duplicate post.  See answer here.
(6,172 Views)
