High-Speed Digitizers
How do I measure time delay between two signals?
I am using Labwindows/CVI 8.5, NI5112 Scope card, on WinXP OS. I have two 790 Hz sine wave signals (one at channel a, and the other at channel B) which are 180 degrees out of phase. I want to measure the time delay between them. I used the "Time Delay" measurement function on the Scope Soft Front Panel but I did not get the expected 0.0006329sec time delay. Also, I tried the "Phase Delay" measurement function. That also did not give me the expected 180 degrees phase delay. The question is how do I set it up on the Scope Soft Front Panel to measure the time delay? Any help would be appreciated.
Thank you.
Robert
(9,073 Views)
This post has been answered here.
Ana P
(9,056 Views)
