High-Speed Digitizers
How do I select the 20 Mhz Bandwidth limit with 5112 Scope card
Having a noise issue (Random, low voltage). How do I limit the 5112 Scope to the 20MHZ Bandwidth?
(5,931 Views)
Joe,
To select the 20MHz bandwidth limit use the "niScope Configure Chan Characteristics" VI in LabVIEW and set the maximum frequency to 20MHz or in any text based programming environment use the niScope_ConfigureChanCharacteristics function call.
Reply back if you need more assistance
(5,931 Views)
