I did a bit more looking and found out that I was wrong.  My apologies.  NI-HWS is currently shipping with the high-speed digital products and the waveform editors (analog and digital).  It is not shipping with NI-FGEN or NI-SCOPE.  sfpFile shipped with NI-SCOPE 2.1.2 through 2.5 and NI-FGEN 1.5.  NI-HWS was not finished in time for the latest NI-SCOPE and NI-FGEN releases.  For now, you will need to use sfpFile.  Copy the examples to make your life much easier.  Your application is simple enough that the basic functions should work for you.  Don't worry about losing your data, since sfpFile and NI-HWS use the same format.  In any case, it is all based on HDF5, and you can get HDF5 utilities (free for any use) from the
NCSA website.  A word of warning - HDF5 is VERY powerful, but also VERY difficult to use.  sfpFile and NI-HWS are based on the 1.4.4 release of HDF5.  The current 1.6.x release of HDF5 is file format compatible, but binary incompatible with the 1.4.x release.  NCSA did not change the format of the files they are writing, but did change the code that writes to them.
