09-18-2018 05:33 PM
I'm working with the NI PCI-5124 scope for real-time acquisition project, I connected the card to Matlab.
In order to build my code, I had to understand and arrange the different functions and properties. I started with the initialization then the vertical and horizontal configuration, preparing the waveform information and finally make a acquisition initialization and carry out the fetch function.
Indeed, I would like to make the continuous acquisition using the circular buffer but each time I increase the number of record in the configuration horizontal timing and after making fetch functions, the program matlab hangs and close. Actually, I have this matlab sentence: '' '' and then matlab goes out. I have set Fetch_Relative_To 483.0 (Read
Pointer4)
Can you help me, how can I make continuous acquisition on Matlab with NI PCI-5124 scope?
I put my in attachment text file
thank you in advance
Ali
12-24-2018 01:18 PM
Hi Ali,
I am also working on the same problem and couldn't get Matlab fetch continuously from the circular buffer of 5124. Were you able to find a solution to this problem?
