High-Speed Digitizers
I have an NI5911 high speed digitizer and would like to acquire a video signal from a CCD using it. Does anyone know if this is possible without buying any more hardware please? If it is, how would I go about it?
The only thing I succeeded in finding on the NI site was about using a different high-speed digitizer in tandem with an IMAQ card but I was hoping not to have to buy an IMAQ card as it means I may as well not have got the NI5911 (a while ago) in the first place. Any help would be greatly appreciated!
(5,901 Views)
You can certainly acquire video signals with the 5911. The only tricky part is that the 5911 does not have any video triggering options. That means that you will have to either find a way to provide your own trigger based on the video signal (that's where the IMAQ board comes into play) or you can just take a lot of data and keep only the data you need once it is in software. For instance, you could take one large record and then use software analysis to determine where the frame sync occurs. Hopefully this was helpful.
(5,901 Views)
