High-Speed Digitizers
Initialization error with PCI-5122
Installed PCI-5122 on a Windows 2000 PC. Device appears normal in MAX. When I load the soft front panel, I get a box that says Auto Setup failed. After hitting OK, I get another error box that says there was an initialization error. The details of the messages are shown in two screenshots.
(7,271 Views)
What version of NI-SCOPE are you using?  Also can you use the Device within the test panels, LabVIEW, or any other environment?
(7,263 Views)
We're using version 2.8 of NI-SCOPE. We also have Lab View 7.0 installed. So far I've only tried to use the scope with its soft front panel - is there another way you know of?
(7,255 Views)
Are you seeing the same problem after you applied the fix from this thread:
http://forums.ni.com/ni/board/message?board.id=310&message.id=937&jump=true
(7,248 Views)
This problem is gone thanks to the apparently unrelated fix with MAX. Thanks.
(7,242 Views)
