High-Speed Digitizers
Is LAbview 7.0 compatible with windows7
I'd like to know if labview7.0 is compatible with windows7.0, i think not but i want ti be sure. My old computer with windows2000 is over.
Message 1 of 9
(11,408 Views)
LabVIEW7.0 is not officially supported on windows seven. But you can also make the test to be sure if it's works or not.
Regards
Message Edité par YannC le 11-30-2009 02:55 AM
Yann C.
France
Message 2 of 9
(11,366 Views)
I have an application which runs, and should reveive data input via a serial input (COM1). No data is received. A control with a terminal program like "Teraterm" shows that the serial port functions OK. I have not tried to port the application to a later version of LAbview. The application functions perfectly on Windows XP.
Message 3 of 9
(10,407 Views)
Did you ever get an answer?  I am having to convert some old legacy Labview7 to a new computer with Windows7.
Message 4 of 9
(8,568 Views)
Hello everyone,
You can find some information about LabVIEW/OS compatibility on the following link.
http://www.ni.com/labview/os-support/f/
Sabri JATLAOUI
Sabri JATLAOUI - Certified LabVIEW Architect - Certified LabVIEW Developer
Message 5 of 9
(8,560 Views)
Useles info for Labview 7 on Win7
Message 6 of 9
(7,745 Views)
Here's a link not uselesS with LabVIEW 7.
https://www.ni.com/en/support/documentation/compatibility/17/labview-and-microsoft-windows-compatibi...
Best regards.
Message 7 of 9
(7,735 Views)
Much better, but still youseless. LabView 7.1 does work with Wi????.
Message 8 of 9
(7,719 Views)
Dear JBMW,
As the previous link said. No.
Best regards.
Message 9 of 9
(7,700 Views)
