High-Speed Digitizers
Is NI-SCOPE available for LabView 2009 in Linux?
The last NI-SCOPE driver update for Linux (v3.1) was April 2010 and is only compatible with LabView 8.01. Is there a new driver which is compatible with LabView 2009 in Linux.
Or is there a trick to importing the LabView 8.01 libraries into LabView 2009, as whenever I try to do this it crashes LabView.
For instance:
For now, I have soft-linked a directory
{natinst}/LabVIEW-2009/inst.lib/niScope -> {natinst}/LabVIEW-8.0/inst.lib/niScope
So if I open a blank vi and open the Measurement I/O menu, I have an niScope sub-menu. I can select a vi from it, for instance "niScope Initialize.vi". I can then drag it into the block diagram, but as soon as I place it, LabView quits completely.
Fresh install of Scientific Linux 5.5 64 bit (a subset of RHEL). Standard install of LabView-2009, standard install of NI-SCOPE3.1.
Cheers,
--Jon
(5,884 Views)
Hi Jon,
It looks like NI-SCOPE 3.1 does not support Scientific Linux 5.5. Extensive user testing is recommended before deploying a system using this configuration.  Here is a chart that explains this:
What Linux Distributions Do National Instruments Drivers and Software Support?
http://digital.ni.com/public.nsf/allkb/4857A755082E9E228625778900709661?OpenDocument
--Michelle
(5,862 Views)
