High-Speed Digitizers
LeCroy Waverunner Query Cmd
Does anyone know the command for a LeCroy Waverunner (620zi) to get the measurement statistics units? The NI low level drivers have the usual read P(x) statistics values and in the Waverunner programming manual I couldn't find anything regarding querying measurement units.
(4,483 Views)
Hello Morben,
Are you using LabVIEW with LeCroy Wavefunner's instrument driver
Saki K.
(4,449 Views)
Hi Saki,
Yes, I'm using the LeCroy inst. driver.
(4,430 Views)
Hi Morben,
There is a VI called configure measure mode listed in the VI tree. Other than that I am not seeing a pre-built VI in the driver. If you have a command set for the instrument you may be able to create a new VI for the driver which makes VISA calls directly to the instrument.
Alex W.
(4,420 Views)
