High-Speed Digitizers
Lecroy PXD222
Hi All.
For my new project the client recommend to use Lecroy PD222 digitizer card.
My questions are:
1.Is this card full functional with Labview 7 or greater version.
2.I have setup with PXI controller with Labview RT. Is this card compatible to use in RT environment.
Any existing user of this card pls comment, any issues faced, bottlenecks, overheads in coding compared to NI digitizers.
Thanks in Advance.
Jemmy
(7,270 Views)
Hi Jemmy,
If your Lecroy PD222 digitizer card has to work with LabVIEW, you would need the LabVIEW drivers for that hardware. National Instruments generally do not make the drivers to work with the 3rd party hardware. Hence, please contact your hardware manufacturer to see if they have developed any LabVIEW drivers for your particular hardware. Also, you can look for 3rd party instrument drivers at the instrument driver network webpage
Prashanth
(7,256 Views)
Hi Prasanth,
Thank you for the response...
I do agree that it need to have a driver to support Labivew , which Lecroy is providing..
My concern is more into the card supporting Labview RT functions..
Thank you once again.
Jemmy
(7,249 Views)
Hi Jemmy,
I dont have much information about this particular card. What did Lecroy say about it working with LabVIEW or LabVIEW RT?
Prashanth
(7,234 Views)
HI,
The local Lecroy support says YES, but no clear information or any reference of any existing user.Probably I may be the first user here:)
I have to consult someone at Lecroy US.
Thank You,
Jemmy
(7,230 Views)
