High-Speed Digitizers
[Linker Error] Unresolved external 'niScope_init' referenced from C:\ALUNOS\ALLAN\EVA\BUILDER2.0B\UNIT1.OBJ
First of all I'm sorry about my English. I'm developing a software on Builder C++ by Borland and we bought an NI DAQ 5112 PCI. I'd like to know if is possible to use the high-level functions from niScope (such as niScope_init, _AutoSetup, _close...) on this plataform. I'm asking it 'cause I could run every "example program" on it whithout any problem. But when I try to use it on my own project the message below is shown: unresolved external "niScope_init" referenced from "path_of_my_project".
thanks,
Allan
(8,969 Views)
Make sure you're linking to the niScope inport library.  I'm attaching the Borland import library from NI-SCOPE 2.9.1.
(These forums won't let me attach a .lib.  So download this file, and rename it "niScope.lib")
(8,963 Views)
thanks psisterhen,
but yes, i'm sure that i'm linking this library. have you ever worked with C++ Builder 6 by Borland?
best regards
merry christmas!
(8,945 Views)
Allan,
If the examples work properly in C++ Builder 6, but your own projects do not work, then I would compare your project settings to find out what it different.  Otherwise, you could just start with an example that is properly linked to the Scope library and modify it to fit your needs.
Have you seen this KnowledgeBase?
Travis W
(8,923 Views)
