High-Speed Digitizers
Maximum tirgger delay allowed on a 5122 digitizer
I am pretty sure I had some documentation on this somewhere; however, neither the latest version of niScope on my computer nor the specs for the board I found on the web  seem to document a max value. I know the type is ViReal64 (CVI programmer  - sorry).
The particular function I am working with is niScope_ConfigureTriggerDigital
In my immediate case I am interested in a PXIE5122 with 64 option. This will be a single channel acquisition.
I thought there was a formula based on the sample clock.
System is Win7 64 bit, CVI 2013 sp2, NI scope 14.1.
Full configuration data from NIMAX attached if needed.
(5,464 Views)
Accepted by topic author blakney
Okay I found a reference here.
http://zone.ni.com/reference/en-XX/help/370592W-01/digitizers/5122-5124_trigger_delay/
Max trigger delay in seconds = [(234 – 1) – requested posttrigger samples] × (1/actual sample rate)
Greg
(5,461 Views)
