Hi Sara,
The reason why the specification sheets for many of our devices state "Indoor Use Only" is for UL compliance.  Any use of the device in conditions other than those recommended in the documentation is at your own risk.
Having said that, I have a few questions:
At what frequency is the noise that you are seeing?
Are there any communications towers/equipment near your device?
Is your 5102 a PXI or PCI device?
What is the source of the signal that you are trying to measure?
Andrew W
