High-Speed Digitizers
NI 5105 - Measure PWM Waveform Duty Cycle
Will the Positive Duty Cycle scalar measurement in the NI-SCOPE software calculate duty cycle correctly on a PWM (pulse-width modulated) waveform?  I have a 400Hz signal that is pulse-width modulated with a 40Hz signal that I need to measure the duty cycle for.  Since this is not a normal, continuous waveform (like a sine wave or square wave) I don't know if the NI-SCOPE software will correctly calculate the Duty Cycle.  Has anyone tried this with success?  I am looking at using the NI-5105 because it has 8 channels, but am open to using other hardware and just multiplex my signals to the digitizer.
(7,102 Views)
The positive duty cycle scalar measurement should correctly calculate duty cycle on your pulse.  By default, the measurement finds the base and top of your waveform using a histogram of the Y values (there will be peaks in the histogram at the base and top values).  Duty cycle is calculated from the 50% level crossings between these two values.  You must have at least one complete cycle and only the first cycle is measured.
If that doesn't work for you, there are a plethora of parameters you can change (except for which pulse you measure - it is always the first).  For example, you can set the upper, lower, and level crossing values to specific % or voltage levels.  See the documentation and examples for details.
If you need to measure the duty cycle of multiple pulses in the same pulse train, there is a LabVIEW function (Pulse Measurements.vi) which allows you to do this.  It uses the same algorithms as the internal NI-SCOPE routines.
In either case, the measurement is independent of the hardware.  Any NI-SCOPE device will work.  If you have any other questions, let us know.
(7,092 Views)
