High-Speed Digitizers
NI 5105 returns error 50550
I found another solution on NI Forum. It suggested that the issue was not the scope 5105 but the chassis on which it was plugged. It left me unconvinced because I didn't know why it would suddenly break down but i still tried. So I switched my 5105 from slot 3 to an available slot and it actually solved everything.
Message 11 of 13
(3,035 Views)
Hi Alex,
So then it's possible there is an issue with that slot 3 on your chassis?  Perhaps you should set up an RMA for that chassis.
Have you seen any other card (digitizer or non-digitizer) have issues with slot 3 on your chassis?
Can you link the other forum where you found that recommendation here?
-Andrew
Message 12 of 13
(3,025 Views)
Hi Andrew,
Here is the post that gave me a hint :
http://forums.ni.com/t5/High-Speed-Digitizers/Error-50550-with-PXI-5122-in-a-PXIe-1075/m-p/1648652
I already tried to unplug and re-plug the NI 5105 card on this slot and it did not work. I will try another card on slot 3 tomorrow.
Alex
Message 13 of 13
(3,022 Views)
