High-Speed Digitizers
NI-5112 Exception error Calling Read() if does not trigger
I am using:
NI-5112
niScope.vb IVI driver wrapped for VB.NET
VB.NET 2005
If I call the Read() function using an edge trigger and the waveform does not trigger I get an exception falut that appears to be an "Invalid Parameter" error that I am trying to trap specifically so I can handle the issue correctly.
What is the best way to trap these timeout Errors?
(6,301 Views)
TrackerMan,
Have you taken a look at the example files for the DAQmx driver?   These are a great place to start when building your application.  They also show the recommended way of catching those errors, using a Try...Catch block around the code.
-Christina
(6,273 Views)
Ok thanks, also would you know why the waveforms from the 5112 are returning with the last value always zero?
(6,267 Views)
