High-Speed Digitizers
NI 5622 Signal Conditioning
Hi
how i can enable the unfiltered (direct path) on the 5622  High-Speed digitizer
(5,869 Views)
Hi hany_anees,
When the 5622 is used as a stand-alone digitizer, the direct path should be enabled by default.  However, you should note that you should implement your own filter to avoid aliasing your acquired signal.
To switch between direct path and bandpass modes, use the following property node:
Here's a link to the online help for that property:
http://zone.ni.com/reference/en-XX/help/370592P-01/scopepropref/pniscope_bandpassfilterenabled/
Chris Elliott
x36772
(5,858 Views)
Hi
thanks
do you have any example for using this property
(5,849 Views)
Hi hany_anees,
This property node just takes a Boolean input; it should be inline with your instrument session, as well.
If you have not used property nodes before in LabVIEW, you may want to read over the documentation for them, here:
Property Node - LabVIEW 2012 Help
Chris Elliott
x36772
(5,842 Views)
