High-Speed Digitizers
NI-Scope SFP w/PXI-5124: Can I enable external 10MHz ref clock using SFP?
I'm trying to acquire data with the PXI-5124 module and the NI Scope SFP only. I'm getting the data, but the sample clock does not seem to be locked to my 10MHz reference, connected to the Clk In port. Is it possible to route the external clock to the PLL with only the NI Scope SFP, or must I program this through a VI or the IVI-C driver?
(6,557 Views)
You cannot route the external clock to the PLL with only the Scope Soft Front Panel. You would actually need to use LabVIEW to be able to do this. Here is an article that gives you a little more information on this.
Best Regards,
Raajit L | Applications Engineer | National Instruments
Raajit L
(6,542 Views)
