High-Speed Digitizers
NI Scope Streaming for LabVIEW 8.0
I am currently working on a data streaming project.  I have been in touch with an NI rep, and he suggested the ni-scope-streaming-basic/advanced examples from the "NI-SCOPE Stream to Disk Using Win32 File IO" page (http://zone.ni.com/devzone/cda/epd/p/id/5273).  Although the recommended software says "LabVIEW 8.0 or above" - I have LabVIEW 8.0 (FDS) and am unable to open the files.  I get an error telling me LabVIEW 8.2 is newer than 8.0.
I was wondering if someone has built the project in version 8.0 or older.  If so, I could you please post it?  If nobody has had this problem before, could you please post a screen shot of the vi in version 8.2 so I can attempt to build it on my own?
Any help would be greatly appreciated.
Eric
(6,755 Views)
I found that my NI-Scope driver was out of date (I had version 2.9.2, and version 3.0 is required for the examples).  After updating my driver, I was able to successfully open the "advanced" examples, but not the "basic" example.  I have no idea why this is happening and I have talked to NI support with no luck.  I should be fine with the advanced example for my purposes, but it would be nice to have a look at the basic version.
Eric
(6,738 Views)
Hi Eric,
Thank you for letting us know that the 'basic example' cannot be opened in LabVIEW 8.0 - I will get this fixed. I saved the 'basic example' in LabVIEW 8.0 and attached it below.
David L.
Systems Engineering
(6,732 Views)
