High-Speed Digitizers
Ni 5112 soft front panel
Hi:
Can you tell me how to mesuare a voltage of 5.1V on soft front panel? Because I got 5.1 volts on soft front panel, but it stop there and
it did not go back to 0V in a horizontal line.
When I used the real osciloscope, I can get that and it will return to 0 volts after 1 to 2seconds pressing the beep button.
What is wrong with it?
Let me providle my setting on soft front panel.
1Mohm, 100Mhz bandwidth, Y-AXIS 2V/div, offset 0, AC couple, CH0, , X-AXIS 10 microsecond/div, 50% reference, Trigger: edge, rising, ch0, normal, trigger level 2.5V
I am in a urgent. I appreicate if you can reply to me promply
(6,531 Views)
I believe this is the same question as this post NI 5112 Scope soft front panel setting problem
If that doesn't answer your question let me know.
Message Edited by Evan on 09-08-2005 10:09 AM
(6,530 Views)
Attached is another diagram, maybe it will help
(6,506 Views)
