High-Speed Digitizers
Ni pci 5112
hello ,
i want to buy a digitizer to measure and analysis  (ni scope toolkit) 2 high frequency simultaneous signals ( for each channel i need 100 Msps adc samling rate), can i do it using ni pci 5112 digitizer?
(4,119 Views)
Hi Mehr89,
The PCI-5112 digitizer is capable of simultaneously sampling 2 signals at 100Msps.
100MHz is the maximum limit and if you're only interested in frequency content of your signal this will be sufficient.
Regards
Alex
Hardware Engineer
(4,092 Views)
Something to be aware of before you make a decision is that the 5112 is only supported on 32-bit Windows Operating Systems.
Jay
Senior Software Engineer
Driver Software
(3,995 Views)
