High-Speed Digitizers
No output on Aux I/O of NI5761
Trying to get output on the PFI (Aux I/O) connector of a 5761, but it does not work.
The NI5761 is connected to a PXIe-7975R.
The highest four bits of the Aux IO are set to outputs by sending 0xF0 to "IO Module\PFI Write Enable", and "IO Module\PFI Connector Enable" is set true.
When I send 0xF0 to "IO Module\PFI Output" the upper four bits should go high, I suppose.
Nothing happens (I see no change on my oscilloscope).
I can read data from the lower four bits.
What am I doing wrong?
(5,495 Views)
Accepted by topic author Kees_D
Hi Kees_D
Have a look through this forum post - it may help:
http://forums.ni.com/t5/PXI/How-to-select-the-PFI-line-to-use-on-the-AUX-port-of-the-5761/td-p/20393...
Please also try setting all 8 DIO lines as outputs, and see if you can write to them this way.
If this doesn't help, please attach some screenshots and/or your code.
Amy
Amy K
National Instruments UK & Ireland
(5,480 Views)
Problem solved. Was a stupid mistake of me. Took output from the wrong pins.
Works ok now. Sorry.
Kees
(5,451 Views)
Hi Kees,
Not a problem, glad you've sorted it!
Amy
Amy K
(5,424 Views)
