High-Speed Digitizers
P7000 Enable input: Error message: Amplifier Disables
I have a P70360 and I want to connect it to a small stepper motor.
When I open P7000 Tools, I cannot probe the motor, since it always says that the Amplifier is Disabled (bottom right corner) and when I hit the "probe" button it says that the drive is fault, disabled, or disconnected.
I have no idea how I can get rid of it.
In the manual it says the following for this error:
Green 1
Amplifier is disabled
The enable input (J4-5 & J4-6) is not asserted if ENABLE is configured ACTIVE CLOSED or the enable input is asserted if ENABLE is configured ACTIVE OPEN.
De-assert the enable input or disable the soft shutdown from P7000Tools.
Can anyone help me with this?
Peter
(6,675 Views)
I had the same issue.
I'm using a UMI-7774 Motion Interface; on the respective axis, above the COM cable connector there are three switches: Fault, Enable, Limit. I put the Enable switch in the "active low" position. In your case, ACTIVE CLOSED = "active low" for whatever type of interface you're using.
Basically, the error message means that P7000 Tools isn't getting the expected signal from the drive. Check the cable connections.
(5,844 Views)
