High-Speed Digitizers
PCI-5102 failed test resources in MAX using window 2000
Hi All,
Some help needed. I facing some problem when did the PCI-5102 software and hardware installation in window 2000, When doing "Test Resources" testing in MAX,i found error message prompt-out "The device did not pass the test.". But inside Device Manager my PCI-5012 is detected. Please refer attachment for the error message in MAX.
softwares & drivers installed;
-NI-DAQmx 8.9.5
-Traditional NI-DAQ 7.4.4 (Legacy)
-NI-VISA 4.6
-NI IVI Compliance Package 4.0
-NI-SCOPE 3.6
* Got any configuration need to be done before i go to test resources? Your help is much appreciated. Thanks
(5,815 Views)
Sound like card is broken already.
You should contact local NI office for repair.
(5,797 Views)
