High-Speed Digitizers
PCI-5124, PCI-6040, need to measure time between 2 pulses, delay, output pulse with microsecond accuracy
Hi all,
Also poted this on the labview board, but maybe this one is better for this question.
I'm running Labview 8.0, and have a PCI-5124 and PCI-6040E to use. My application is to trigger on 2 pulses (trigger#1 and trigger#2) with the PCI-5124 (pulses are about 200ns width, the 6040E does not trigger reliably on them) that will come at random times, but within about 500us of each other. Then, the time between the incoming trigger pulses must be measured to within about 1us. I will be triggering a laser to fire with a digital pulse output (presumably from the 6040) sometime after the trigger#2, based on this time that was calculated. Basically the flow goes as follows:
1) recieve trigger#1 (on PCI-5124)
2) receive trigger#2 (on PCI-5124) around 500us later.
3) calculate time between trigger#1 and trigger#2, and use this to calculate a delay time (DELAY)
4) Put out a digital pulse at time DELAY after trigger #2; DELAY will be about 1.5-3ms, must be accurate to within +/- a microsecond or so.
So far my main trouble is getting everything synchronized - the triggers come, and I get them by using Ni-scope functions to collect two very short samples (1 point). Then, I fetch the two 1pt waveforms and use the waveform output of absolute timestamps to calculate DELAY. I have a task where the 6040E count edges of a 1MHz square wave as a "clock", and try to output a digital pulse on the 6040 when the clock reaches the value of (trigger#2 time + DELAY). Some big problems are, the way I check the "clock",  the pulse out has a jitter with respect to trigger #2 of +/-50us, which is way too much. The fetch function itself also seems to take about 0.8ms even if I only fetch 1 point.
So I guess my most pressing questions are:
1) what should I use as a "master clock" for this application?
2) How do I make sure that once I calculate the appropriate time to put out the digital pulse (DELAY+Trigger time#2), a digital output comes at exactly this time (+/- 1us)?
3) Is there a faster way to calculate the time between the 2 trigger pulses than my "fetch and check timestamp"?
Help with any of these questions would be greatly appreciated; I'm new to Labview and I've been spending a lot of time trying to figure out how to solve this problem which sounded fairly simple in words. Attached is my latest crack at it, but I would rather start again with a more efficient way overall instead of forcing this to work if that's easier. Thanks for taking a look at this!
Message 1 of 1
(7,373 Views)
