High-Speed Digitizers
PXI 5105 offset
i'm using a PXI 5105 with LV SignalExpress.
I want to measure the voltage of embedded system card with power supply of 5 V.
I want to tune the offset but when i set a value, i have the error:
"Requested vertical offset invalid."
Voltage Range is : 5V
Offset is : 4V
Impedance is : 1Mohms
What's wrong ?
Best regards
Nicolas
(6,849 Views)
Accepted by topic author nferry
Hi Nicolas,
Unfortunately, the NI 5105 does not support voltage offsets. For a quick rundown of supported features, please refer to the Features Supported by Device section of the High-Speed Digitizers Help. Best regards,
Daniel S.
(6,842 Views)
Hi Daniel,
Thank you, i miss this one.
Best regards
Nicolas
(6,813 Views)
