High-Speed Digitizers
PXI-5122 Continuous data acquisition
Hello forum,
with the PXI-5122 I would like to record data with the highest possible sampling rate (=100 MHz) for a total record length of 5 s to 10 s. However, the on-board memory is not sufficient enough for this purpose.
For programming I use python and would like to use the package "niscope". Do you have any help how I can implement a continuous data acquisition /data streaming from the ADC to the PC while recording - such that there is no memory error?
Thanks for your help already in advance.
Message 1 of 1
(2,881 Views)
