High-Speed Digitizers
PXI-5122 PFI output pulse
PXI5122
It is not very clear if I can do this but is it
possible to arm the PXI5122 (awaiting an
external trigger) and output a pulse on
either of the PFI lines?
The 5122 PFI will trigger ext hardware and
the 5122 will read the result.
I am trying to use the READY FOR START EVENT
which states 'generate a pulse when the digitizer is
initiated and ready to start acquisition to begin sampling'
TIA.
Message Edited by csk on 12-02-2008 09:31 AM
(7,035 Views)
Accepted by topic author csk
Hi
Yes, you can use the niScope Export Signal.vi to output a digital pulse on one of your PFI Lines when a certain condition is met.  From your post it sounds like you might already be using this VI.  I attached a screenshot of the Export Signal VI and included the context help and detailed help regarding what signal parameters are available.
Jordan F
(7,016 Views)
