High-Speed Digitizers
PXI NI5112 data acquisition
How long does the function niScope_InitiateAcquisition() take?
(5,903 Views)
The time that this function takes is system dependant. I tried it on a PXI-8170 controller (700MHz Intel Pentium III processr with 256 KB RAM) using LabVIEW 6.1 and it took between 34 and 37 msecs.
Keep up the good work and good luck with your project.
Annette Perez
(5,903 Views)
Thank you for your response!
There are 4 PXI NI5112 in my system.I call the function niScope_InitiateAcquisition() for each NI5112 in sequence and I found that there are a time difference of 70 msecs among each NI5112.
1.How can I avoid this time difference?
2.How can I let the clock of each NI5112 start at the same time?
(5,903 Views)
I am trying to do something similar. I am able to synchronize the cards,
but I cannot start the acquisitions close enough. Does anyone have a
solution to this?
Thanks!
(5,903 Views)
