High-Speed Digitizers
PXI5154 external trigger input
I need to use a photo diode to generate the external trigger of PXI5154 board. I am wondering what's the range of the trigger signal that the board can accept -- both the range of trigger voltage and pulse width?
(3,352 Views)
Hello cls_user,
I would recommend taking a look at the PXI-5154 Specifications. Pages 9-11 talk about triggers. For an external trigger, I see that the voltage range is ±5 V.
Regards.
(3,331 Views)
