High-Speed Digitizers
Programming NI-5122 in Visual Studio 2005 with multithread mode can cause hang
I'm developing an application in Visual Studio 2005. I called NI-Scope APIs in a working thread. The software can talk to NI-5122 successfully, which I can see from NI-spy. However, after that, the UI hangs up. When I debug the program, Visual Studio tells me there is some deadlock among some threads. I attached the application used to reproduce this problem. To reproduce this problem, you just need to click the "Run" button on the dialog. Here is my developing settings.
Hardware: NI-PCI-5122 digitizer (the device name is "Dev1" in MAX)
Software: Windows XP+Visual Studio 2005+NI-Scope 3.3.0f0.
Please advise.
Jucao Liang
(7,955 Views)
Hello Jucao,
Before calling your thread which uses the scope driver, there are some components that must be loaded.  To load these required components you can simply call into the scope driver.  In your code if I place the following code into the OnBnClickedRun() method before creating the new thread everything works.
ViSession vi=VI_NULL;
niScope_Init("Dev1",VI_FALSE,VI_FALSE,&vi);
niScope_close(vi);
Jesse O.
Applications Engineering
P.S. You might want to update your user profile to contain a valid email address.
Message Edited by Jesse O on 05-23-2007 06:01 PM
Jesse O. | National Instruments R&D
(7,929 Views)
Dear Jesse,
Thank you so much. I tried your solution and it worked pretty well. Maybe you can add this as a KB so the other customers can also benefit from that.
As to Email address, I used to be NI employee and I just left NI. That's why you see jucao.liang@ni.com. 🙂
Thanks again.
Jucao
(7,926 Views)
Hi Jucao,
Keep in mind that you just need to call this extra code once within the main thread.  I have modified your .cpp file by placing these calls in your CMT_Test_NI_DGT_AWGDlg:: OnInitDialog().
Another solution is to call
#include
"ivi.h"
IviConfigStoreHandle handle=NULL;
Ivi_GetConfigStoreHandle(&handle);
from the main thread.  To use this solution, you will need to be sure to link to the ivi.lib library.  The attached file has both workarounds in place, with the IviConfigStoreHandle method commented out.
I hope this helps.
Sean Close
Product Support Engineer: High Speed Digitizers
Message Edited by Sean C. on 05-24-2007 10:17 AM
(7,911 Views)
Hello Jucao,
In order to recieve subscription notices from the NI Discussion Forums, you can change your email address by going to ni.com/profile and clicking Modify Profile.
Laura
Web Support & Operations
(7,884 Views)
