High-Speed Digitizers
RMA Request
We need to have our PXI-5142 digitizer to be repaired (S/N: EA9261) Thanks in advance.
(7,024 Views)
To have your device begin the RMA process, go to the following link and click "Repair or Calibrate":
https://www.ni.com/contact-us/
Systems Engineer
SISU
(7,020 Views)
Sorry, but there is no "Repair or Calibrate" link.
regards
(7,018 Views)
Hi Ibrahim,
Does the 'Repair or Calibrate' link not appear in the 'Technical Support' section?  If not, you can also try the Troubleshoot a technical issue link, or give us a call at 1-866-275-6964, we'd be happy to help you out with this!
(7,006 Views)
