High-Speed Digitizers
Sampling rate settins for NI-5112 PCI device using SCOPE soft front panel
I need some help on adjusting/changing the samppling rate (currently showing 200MS/s) of the NI-5112 scope card via the SCOPE soft front panel. Can anyone help?
Kranti
(6,396 Views)
You can change the sample rate using the Time/Div control.  In addition the number of samples (Edit>>Device Configuration) has an effect on the sample rate.  Basically as you change the number the SFP tries to keep the same amount of time for the acquisition, so it changes the sample rate.
(6,386 Views)
