High-Speed Digitizers
Test Tab for waveform graph and pass button
Hi Psisterhen:
I have not heard from you more than a week. I would like to ask what is happening. I did not want to bother you in these few days even though I am in a hurry.
Could you please write me back what is happening with you?
Message 31 of 33
(3,555 Views)
Hi Psisterhen:
How are you? What is actually going on?
If you don't have experience on something like tab control, using keyboard netvigation on tab control or making the reading continouly to read. That is OK. No one knows everything. But if you know how to get a microphone and which software to use for the beep test. Would you pls let me know? I really need your help.
Would you please write me back? At least I know what is going on and I can solve the problem, right? Please write me back.
Message 32 of 33
(3,547 Views)
When I said the "power" of the signal, I meant (for your application) the voltage.  You need to set the vertical range of the digitizer to account for the expected voltages of the signal you will measure.
When you set the Key Navigation for a tab control, it selects the entire control, not specific tabs.  To navigate between the tabs on the control, simply use the arrow keys on your keyboard.
If you want to jump from one tab to another programmatically, you need to create a property node for the tab control and set the Value (Signaling) property.  This changes which tab is displayed.  To create the property node, right-click on the tab icon in the block diagram, then select Create >> Property Node.  I am attaching an example for you.
Like I said before, programming your application to recognize and respond to an external beep is much more complicated than you think.  A microphone will not send a digital signal, but rather an analog signal representing the sound.  You will need digitizer (like a National Instruments MIO, DSA, or High-Speed Digitizer device) in your machine to digitize this signal and bring the data into LabVIEW.  At that point, you will have to analyze the data to determine if there was a beep.  This will probably not be a simple task because you have to distinguish the specific beep from surrounding noise and other sounds.  There are many different ways to design this system, but these forums are not an appropriate place to discuss this.
Also, I do not believe these forums can continue to provide the help that you need.  Most issues are handled in one or two replies, because they deal with specific, limited issues.  Your threads are spanning dozens and dozens of posts because you require assistance at every level of your project.  These forums are not intended to require specific members of the community to provide ongoing consultation to application development.
For you to be successful, I recommend that you arrange to take a NI Customer Education class or seek out a 3rd party consultant.
You should not post questions to the High-Speed Digitizers forum unless they are about High-Speed Digitizers or the NI-Scope driver software.
Good luck.
Message 33 of 33
(3,537 Views)
