High-Speed Digitizers
Trigger from the ac mains power using DAQ PXI 5154
I have a PXI chasis with an embedded controller and a DAQ 5154. I have developed LABview code to trigger on input from channel 0 or 1 but now I require to trigger on the ac mains power i.e. I require to synchronise my measurement with the ac cycle. Have no idea how to go about it.
(5,929 Views)
Hey,
This is definitely an application that you're going to have to spend some time researching, because it will involve some external circuitry.  You will need to transform the three-phase AC power to single-phase and attenuate it to a -2.5 to 2.5 V signal, such that it can be acquired by the 5154 without damaging the device.
As for triggering and synchronizing your signal with the AC power cycle, here is a DevZone article that discusses the different mechanisms of triggering that are possible with digitizers.  You could trigger a finite acquisition at certain points of the acquired sinusoid using an edge or window trigger, for example.
Sara Lewandroski
Applications Engineer | National Instruments
(5,908 Views)
